Update x,y points after adding new data to existing feature class. ArcGIS Pro 2.8
6950
5
09-03-2021 02:06 AM
MarcusNielsen
Hello
I have added some new data to an existing point layer i have hosted online. I used the append tool to add the new data, this includes x and y coordinates.
All the data shows up fine in the attribute table. But there are no new points generated.
Is there a way to update the feature class to include the new x, y coordinates. So they appear on the map?
Thank you.
2 Solutions
DanPatterson
MVP Esteemed Contributor
Append (Data Management)—ArcGIS Pro | Documentation appends featureclasses
you will need to use the coordinates in your table to make a featureclass first like
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
David_Brooks
MVP Regular Contributor
@MarcusNielsen , yes you can either use XY Table To Point (Data Management)—ArcGIS Pro | Documentation or create an Event Layer and append that. XY Table to Point is the better route.
David
..Maps with no limits..
David_Brooks
@MarcusNielsen , coordinates in an attribute table don't necessarily mean you'll get point geometry in your feature class. Have you accidentally just appended a table to a feature class? If so, you get additional rows in your attirbute table with no actual geometry assigned.
What was it you appended to the target point layer? A point feature class from a file geodatabase? A shapefile? etc
David
MarcusNielsen
Thanks for the reply.
Yes i have an seperate table with the new data. I just appended this to the target point layer.
So do i need to make the table into a feature class first?
David_Brooks
David
MarcusNielsen
Thank you very much for your help.
DanPatterson
