untools not show up under Add Packages
1909
07-04-2018 10:20 AM
HungTruong
I follow instructions Install the Utility Network Package Tools toolbox—Get Started | ArcGIS for Gas  to add untools, but it does not show up I search for untools.
Any fix soon?
DanPatterson_Retired
did you reboot/logout of pro? according to the last step
http://solutions.arcgis.com/gas/help/gas-utility-network-configuration/get-started/install-the-utili...
Once complete, close ArcGIS Pro.
The next time you open ArcGIS Pro the Utility Network Package Tools will be installed and can be accessed in the geoprocessing toolboxes.
HungTruong
The untools are installed but not show up on the Geoprocessing Toolboxes. I ended up adding it to the project Toolboxes manually.
That would be the backup plan... glad it worked
