Unexpected result for Extract values to points in Arcpy
924
10-07-2020 11:48 AM
mariasheikh
I am working on spatial interpolation. To extract values for my required points, I am using "Extract values to points" tool from Spatial interpolation toolbox. The tool is working good in ArcMap 10.5. But when I try to use the tool from ArcPy. Same value is generated for each point in test set.
Here is my code:
         #point extraction
         # Set local variables
         inPointFeatures = "test.lyr"
         inRaster = "out1"
         outPointFeatures = "extractvaluespts.dbf"
         # Check out the ArcGIS Spatial Analyst extension license
         # Execute
          ExtractValuesToPoints ExtractValuesToPoints(inPointFeatures, inRaster, outPointFeatures, "INTERPOLATE",          "VALUE_ONLY")
My code for test point layer is as follow:
          ##XY layer for test
         # Set the local variables
          in_Table = "test.csv"
          x_coords = "LONGITUDE"
         y_coords = "LATITUDE"
          z_coords = ""
         out_Layer = "test"
         saved_Layer = r"C:\Users\myc\Desktop\thesis combine\weather parameters\max temp\with elevation\chk1\test.lyr"          # Set the spatial reference
         spRef = r"Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj"
          # Make the XY event layer...
          arcpy.MakeXYEventLayer_management(in_Table, x_coords, y_coords, out_Layer, spRef, z_coords)
         # Print the total rows
         print(arcpy.GetCount_management(out_Layer))
         # Save to a layer file
         arcpy.SaveToLayerFile_management(out_Layer, saved_Layer)
I am unable to understand the reason behind this error? P.S. When I work with geostatistical analyst tool set and GA to points, it works perfect, but I require to use raster calculator that's why I cannot use Geostatistical analyst. How can I fix this?
