Unexpected field alias behavior when renaming field via Fields View
1380
06-09-2023 07:02 AM
Bud
Legendary Contributor
ArcGIS Pro 3.1.2; mobile geodatabase standalone table
In the Fields View, if I rename a field, the field's previous name gets used as the field alias.
Why is that happening?
Video:
(view in My Videos)
Bud
Esri Case #03362627 - Unexpected field alias behavior when renaming field via Fields View
These are the steps to reproduce:
  1. Create two mobile gdbs: mgdb1 and mgdb2
  2. In mgdb1, create a non-spatial table with a text field: T1.
  3. Copy the table to mgdb2.
  4. In the table in mgdb2, delete the field alias. Save.
  5. Rename the field from T1 to T2. Save.
Notes:
  • The field alias for T1 in the table in mgdb1 does not need to be delete before copying.
  • The behavior only occurs if the table is copied from another mgdb. The behavior does not occur in the table in mgdb1.
  • The Field table must be opened by right-clicking on the table in the Catalog > Data Design > Fields. The issue is not reproducible if the Fields table is accessed by right-clicking on the table from the Contents. This is why I was not able to reproduce originally. Opening the Fields table from the Contents would be the workaround to use until the bug is fixed.
BUG-000159633: In a mobile geodatabase table in ArcGIS Pro, the field alias gets automatically set to the previous field name.
Bud
Notes:
