UNDO "Make this the only selectable layer"
778
09-11-2025 09:39 PM
Labels (2)
Nabaz_Gharib
this question was asked 4 years ago, but still no solution.
Solved: UNDO "Make this the only selectable layer" - Esri Community
apparently, it should be simple and straightforward, but practically it is a pain.
I have 4 CAD layers in a map, and I made one of them as only selectable, the problem is the CAD files are groups within groups. now when I want to make all layer selectable I have to go to all groups expand them and make all of the selectable.
this procedure is fine for on time, but for several time it is simply a pain. I looked at arcpy to find away iterate over layer to make all of them selectable but could not  find  a solution.
i hope make this would be added as feature to arcpro or some post a solution here.
MitchHolley1
MVP Alum
If you go to Contents pane in the 'Selection' tab, you can select all the layers you want to turn on, then hold CTRL + SPACE bar. That should select/unselect the layers.
