Unable to rename feature class
1469
11-06-2024 08:38 AM
JasonHoward
We have an intermittent issue where if we attempt to rename a feature class in an enterprise geodatabase, ArcGIS Pro just hangs and the process has to be killed.  When we do that, and reopen Pro, the feature class will have been renamed, but it will have been un-registered with the geodatabase (which is easy to fix).  In additional to that, the old name will still be in the GDB_ITEMS table.  That can be resolved manually.  It's an annoyance that we can work around, but we shouldn't have to.  We are at the current version of enterprise geodatabase.  We are also at the current version of Pro.  And I have re-opened the ticket with Esri.  Has anyone else encountered this issue?
ShaneONeill_144
