Unable to Edit PostgreSQL Layers in ArcGIS Pro – Only Views Are Added
3168
6
04-15-2025 02:54 AM
Labels (3)
wasfymohammed
Hello everyone,
I'm facing an issue when connecting my PostgreSQL database to ArcGIS Pro. I am using a user with superuser privileges, so I have full access to the database and its contents, including editing rights.
However, after I successfully add the database connection and drag layers into ArcGIS Pro, the layers appear as read-only views. I am unable to edit the features or create new ones using the "Create Features" tool.
I'm wondering why this happens. Given that I have superuser privileges, shouldn't I be able to edit the layers directly?
Has anyone faced this issue before? Any suggestions or workarounds would be greatly appreciated.
Thanks in advance!
Tags (1)
George_Thompson
Esri Notable Contributor
Is the PostgreSQL DB an "Enterprise Geodatabase" (with SDE schema)?
If not, you cannot edit the data directly in a database (non-geo): https://pro.arcgis.com/en/pro-app/latest/help/data/databases/databases-and-arcgis.htm#ESRI_SECTION1_...
https://esriaustraliatechblog.wordpress.com/2023/02/12/can-i-edit-data-in-a-database-not-enabled-as-...
Hope this helps!
--- George T.
wasfymohammed
Hi George,
I used the second option — uploading the required layers to ArcGIS Portal, then adding them to ArcGIS Pro, as described in this link (https://esriaustraliatechblog.wordpress.com/2023/02/12/can-i-edit-data-in-a-database-not-enabled-as-...).
However, I ran into the following issue:
Message: Unable to complete operation.
Details: Rowbuffer creation failed. Underlying DBMS error [ERROR: Geometry has Z dimension but column does not]
The geometry type of the layer is MultiLineString, 4326.
Is there a solution for this?
I tried enabling the Z dimension, but then I encountered other errors like:
ERROR: Geometry type (LineString) does not match column type (MultiLineString)::SQLSTATE=22023
ERROR: Geometry has M dimension but column does not
George_Thompson
I am not sure on that specific error message. Do you have a need to the Z value to be enabled?
If not, may want to recreate it without the Z value.
--- George T.
wasfymohammed
George_Thompson
I would recommend contacting Technical Support on this. It may take more detailed troubleshooting than we can accomplish in this forum.
If you enable the database as a geodatabase and register that layer with the geodatabase, I wonder if the behavior is different.
--- George T.
AlfredBaldenweck
MVP Frequent Contributor
Are the tables versioned? If they are, you would need to edit them in a version.
