txt2las not working in arcgis pro
413
01-21-2021 09:23 AM
AmitaGnana_Prakash
Hi, I have lidar data as text file.
I converted it to las file using txt2las.
After running the tool, I got the message that the tool has run successfully.
However I am unable to open the las file.
What could be the reason?
Thank you in advance
Robert_LeClair
Esri Notable Contributor
Amita - you'll have to create a LAS Dataset stored in a geodatabase to work with *.las files in ArcGIS Pro.  You can learn more about how to create the LAS Dataset here.  If you have only 1 *.las/*.zlas to work with in ArcGIS Pro, it can be used for the following items listed here.
