Trying to use Create Routes tool, but ArcGIS Pro 3.0.2 crashes when running
576
11-01-2022 06:23 AM
Labels (2)
RomeoBSDD
I have a layer of lines which represent pipelines for my county's sewer system.
I am trying to create points along the lines which represent defects (cracks, root intrusions, encrustation, etc.) using linear referencing. I've never done this process before, but as of right now I'm trying to run the Create Routes tool to convert my lines into routes, and whenever I do, ArcGIS Pro crashes. I've already submitted an ESRI report, but figured I'd ask here in case somebody had a quick fix or workaround.
Parameters:
Input Line Features: '723 Main' (Joined layer)
Route Identifier Field: 'COMBINED PACP SCORES.csv.Full ID' (Field which contains unique identifier for each pipe segment i.e. 723-02_723-03 or 723A-31_723A-32)
Measure Source: Length of features
Coordinate Priority: Upper left corner
Measure Factor: 1
Measure Offset: 0
Ignore spatial gaps and build index both checked off
If anything needs to be clarified, please let me know.
Thank you.
