Trying to filter change Map Extent properties
992
06-02-2025 06:42 AM
lisaswarnNJDOH
Good Morning,
I have created a state map with information. I then insert a new layout, first, of the state, and then of particular counties I wanted to highlight.
This was working fine until I realized I wanted to whiteout the counties which are not the focus (purple Xs in the picture attached). However, when I try to do this, it affects all the map frames.
Is there a workaround for this?
Tags (1)
JesseCloutier
Esri Community Manager
Thanks for bringing your question to Esri Community, @lisaswarnNJDOH.
Because this area you've initially posted to is designed for feedback specific to the Esri Community platform, I'd like to help get your post moved over to one of our conversation boards where it's more likely to be seen and responded to by members who can help. Which ArcGIS product are you using?
Jesse Cloutier
Community Manager, Engagement & Content
lisaswarnNJDOH
ArcGIS Pro
JesseCloutier
Thank you for confirming. I've moved the post to our ArcGIS Pro Questions Board. All the best!
Jesse Cloutier
