Trying to clone Python environment Pro 2.9/2.9.3
3315
09-22-2022 11:50 PM
marco_vertigis
After updating from 2.8.x to 2.9.3 my conda environment went broke, so I had to recreate it. When I tried to create it either with the Pro UI or with the Command Line I always ran into the following error:
ERROR conda.core.link:_execute(700): An error occurred while installing package 'esri::jupyter_contrib_nbextensions-0.5.1-py_23'.
LinkError: post-link script failed for package esri::jupyter_contrib_nbextensions-0.5.1-py_23
location of failed script: C:\Users\mema\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Scripts\.jupyter_contrib_nbextensions-post-link.bat
==> script messages <==
<None>
==> script output <==
stdout:
stderr: Traceback (most recent call last):
File "C:\Users\mema\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Scripts\jupyter-contrib-nbextension-script.py", line 5, in <module>
from jupyter_contrib_nbextensions.application import main
File "C:\Users\mema\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\jupyter_contrib_nbextensions\__init__.py", line 5, in <module>
import jupyter_nbextensions_configurator
File "C:\Users\mema\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\jupyter_nbextensions_configurator\__init__.py", line 17, in <module>
from notebook import version_info as nb_version_info
ImportError: cannot import name 'version_info' from 'notebook' (C:\Daten\repos\Printing\Engine\notebook\__init__.py)
return code: 1
Then I deinstalled my Pro installation and cleaned up all directories. But got the same behaviour afterwards on a fresh 2.9 installation. Any tips on this one?
marco_vertigis
