Trying to clone Python environment in ArcGIS Pro 2.6
7721
18
07-30-2020 12:17 PM
EvanAird
I have been unable to clone the default Python environment in ArcGIS Pro.
can
How do I install Conda so that running the following command will create the clone?
conda not recognized
DanPatterson
MVP Esteemed Contributor
Other cloning issues, not directly related perhaps...
https://community.esri.com/thread/257842-another-pro-26-clone-problem
... sort of retired...
DuncanHornby
MVP Notable Contributor
I had to completely uninstall 2.6  (which was an update from 2.5). Download 2.6 from MyEsri, reinstall and only then could I clone the default environment..
EvanAird1
I was hopeful based on this post that the same would work for me, but no such luck.
DanPatterson
What was the error? You never did report what it was
JoeBorgione
Yesterday I was able to complete my clone for 2.6.  I have a directory at the C: level called EnvClones and that's where I send my clones to, calling them what makes sense like (drum roll) clonepor26.
I don't like using the esri default clone location as it involves way more digging than I care to.
Once I got the clone created, I use conda to install spyder.  I was having a problem with another package clobbering spyder when I added that package with conda, so I used pip to install it and things seem to be behaving as they should. At least for now.
Cloning and ArcGIS seems to have a little attitude; someday maybe it'll get better instead of worse.
DanPatterson
I think that people having cloning issues should really report these to Technical Support.
They might notice... be a storm trooper not a Dolly
On that final note... I don't use clones and I install everything in the base environment, but my machine is MY machine.
If things go bad... deleting/renaming all folders related to esri (there are only a few) and re-running the install from the  *msi can be completed over a coffee break.
JoeBorgione
Bringing Kory Kramer‌ into the fold; I'm past the point of calling technical support, and my guess is that adding packages is a 'customization'.  If that is in fact the case, users on on their own; that was my experience with an ESRI solution recently.  I mentioned in my other post at that time we had two complaints; myself and one other.  Now it seems to be a trend.
EvanAird1
This issue has been resolved with help from ESRI tech support. I had to change the path in <USER>\AppData\Local\ESRI\conda\envs\proenv.txt from an old clone back to the path of the default Python environment, C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3. I then followed the instructions at https://support.esri.com/en/technical-article/000020560.
DuncanHornby
Nice one!
