Trouble splitting a shoreline polygon
1296
02-04-2024 01:59 PM
Jill_Clogston
I have a polygon of the marine waters of the Salish Sea I am trying to split into five smaller areas. I have successfully split out the Strait of Juan de Fuca and Hood Canal, however, I am trying to split along the line I've drawn below: Split Feature Question.pngSplit Feature Question.png
I have been using the sketch line and following the polygon border and I should end up with four features, but this produces many, many more. I suspect when I draw my split line I need to mark each vertex of the original border as I am ending up with several "mini" polygons along my drawn line (if that makes senses!) If so, is there an easy way to see those vertices so I don't miss any when I'm drawing my split line?
Split Feature Question 2.pngSplit Feature Question 2.png Thanks for the assist!
Jill
DanPatterson
MVP Esteemed Contributor
following the polygon border probably isn't going to be good, just use a cut line straight across from one shoreline to the other.  You can reaggregate parts back together once you are done and/or modify the boundaries once the major splits are complete
... sort of retired...
DanPatterson
Jill_Clogston
Thank you Dan!
Jill
