transparency
1498
7
06-10-2020 01:23 PM
by Anonymous User
Not applicable
Transparency is only working for some polygons in a single layer, but not all, #ArcGIS Pro
DanPatterson
Ian Redding‌ is there a chance that transparency has been set to an attribute or similar for that layer?
Vary transparency by attribute—ArcGIS Pro | Documentation
... sort of retired...
by Anonymous User
Not applicable
No, it's set to None for Transparency by Attribute.
DanPatterson
next questions would be:
what polygons are not being set to transparent?
are you using plain color? symbols? some fill pattern?
A screen grab or some description would help
by Anonymous User
Not applicable
It's a layer derived from a clip and then a union so maybe the stacking of data is affecting the transparency? This is 90%. If I set it to 100% it all disappears, so it is functioning. Pretty sure it has to do with how I created this layer.
DanPatterson
You can do that check yourself, if you click on a spot in the dark red and check the table.  I suspect that you will have more than one feature selected if there was indeed overlap in the original layers.
by Anonymous User
Not applicable
Nope, tried it and there's only one feature selected. I'm at a loss.
DanPatterson
run
Count Overlapping Features—Help | Documentation
to confirm
Union will keep overlaps.
Make sure that it is a singlepart shape and not a multipart
Multipart To Singlepart—Data Management toolbox | Documentation
If union doesn't work
How Union works—Help | Documentation
Export it to a new featureclass and symbolize that
