Transfer Field Domain Descriptions Not Working
1594
07-19-2022 12:58 PM
MollyMarks
This has been a consistent on/off problem since I have regularly been using Pro in my job for the last 2 years. Say I want to "copy" a feature class into a different geodatabase with the same schema. Typically I would use "Feature Class to Feature Class" and in the Environments check "Transfer Field Domain Descriptions" in order to keep all of the domain options for my fields.
I have found that this works 50% of the time. When I open up the Fields view for the new feature class I just created using this method, the domains are not there at all. Sometimes when I exit out of Pro and re-open, they do show up. Other times they are simply lost. Sometimes the domain isn't set in the Fields view but is populated in the Domains view, so I try to set the domain on the Field and get the error "Relationship between the items already exists".
Like I said it's not consistent. Looking to see if anyone else experiences this or if there are any tips for ensuring that all the domains I need from my "original" feature class make it to my "copy" feature class in a different geodatabase. This has happened for me with both file geodatabases and enterprise SDE geodatabases.
Tags (3)
RhettZufelt
MVP Notable Contributor
Right click the dataset in Catalog, select copy, switch to database, paste.
will copy the feature class and all domains associated with it.
R_
