Tmp folders
2348
08-02-2023 04:19 AM
Arp_148
One of my project folders are filled with 119x folders named tmp_1, tmp_2, temp_3 and so on. I assume these are temporary files.
Why are these not automatically deleted?
Can I delete them manually?
DanPatterson
MVP Esteemed Contributor
what is in a folder?   file extensions?   (open them in Notepad++ to see if they are text)
Were you working with rasters? images?
You can delete them manually (back them up to a USB if you are afraid of project issues),
but why not go into you projects and clear your history (Project backstage) of unused clutter regularly
... sort of retired...
Arp_148
The folders contains prj-files. One of the folders contains a (LAS) raster. I think all was created when I runned a mosaic process on LAS-data.
But it concerns me I would have to delete the history line of my work just to get rid of temp-data. Is this really correct (?)
Arp_148
Bump..
DanPatterson
Tech support would be your best option since that is the current state.  They may have come across other options
