Hydrology Flow Direction Tool results in stretch (not D8) when DEM is large
1163
01-19-2024 10:14 AM
Hemlock_Grove
While using the spatial analyst hydrology toolset on a DEM raster, I am finding that the output of the Flow Direction tool is a black and white stretch (with values outside the range of 1-128 as it should be for D8) when the DEM is 'large.'
If I clip the DEM (and I'm not sure of the threshold here or what it's based on-- small town size seems to work, county-wide is too large) it seems to work property with 8 distinct color classes.
I am filling the DEM prior to running the flow direction.
Any Ideas?
Oveys_Ziya
I am facing the same problem. Were you able to solve this?
