Tips about nulls in SQL
5615
07-02-2022 01:18 AM
Bud
Legendary Contributor
What are some tips about nulls in SQL you can share? As GIS professionals, not SQL developers, it's easy to make mistakes when dealing with nulls in SQL.
For example:
  1. We can't do math on nulls: 1 + NULL = NULL.
    1. Sometimes, people assume nulls will be automatically treated as zero. But that's not the case. We would need to explicitly convert nulls to something else (like zero) using COALESCE(), NVL(), etc..
  2. NULL doesn't equal NULL. More specifically, null is neither equal to, nor is it not equal, to null.
    1. WHERE NULL = NULL won't return any results. Neither will WHERE NULL <> NULL.
    2. Further, be careful for cases like WHERE A <> B. Let's say A is 1 and B is null. That row won't get selected, because null is neither equal to, nor is it not equal, to anything.
    3. Joining on null values won't work either.
    4. Related:
  3. Aggregate functions such as AVG() will ignore nulls. AVG(4,4,4,4,4,NULL) will evaluate to 4 (not 3.33).
  4. But be careful when doing math on the result of aggregate functions. Example: SUM(A) + SUM(B). Remember, we can't do math on nulls. So if the result of either of those aggregate functions is null, then the entire expression will evaluate to null.
  5. Different databases concatenate nulls differently. For example, in Oracle, nulls will be ignored in this concatenation: 'FOO ' || NULL || 'BAR' …will evaluate to… FOO BAR. But in other databases, that would result in NULL.
  6. Different databases treat empty strings differently. For example, in Oracle, SELECT '' FROM MY_TABLE will result in null. That's important to know for things like #1 above. We wouldn't want to replace NULL with '', since '' would simply result in null. With that said, putting a space ' ' between the single quotes would work; that won't get automatically converted to null.
Are there any other gotchas or tips about nulls you can share? Or any improvements or corrections to the points above?
Related:
Tags (3)
DanPatterson
MVP Esteemed Contributor
Don't use them
The solution to <null> in tables - Esri Community
query out the defaults before using the remainder
Somewhat tongue-in-cheek, but setting a value to replace a null, which as you point out, enables you to get at valid data.
The downside is that it requires an extra step to get there.
... sort of retired...
Bud
There are some good comments in this sister post:
Oracle Groundbreakers Community - Tips about nulls in SQL
