Tilt for raster layers
2201
7
03-07-2024 09:17 AM
CamiloDavis
Hey
I am struggling with comparing to raster layers because one of them is at a different angle. I checked the projection and they both match. The pixel types are different one is short and the other is double precision but i am not sure how to change that or what else to do.
Robert_LeClair
Esri Esteemed Contributor
Interesting.  Is there a Geographic Transformation applied in the Map View properties by chance?  If so, remove it and see if the raster returns to proper XY axis.
CamiloDavis
How do if figure that out. Where can I find Map View properties?
CamiloDavis
Is this what you mean?
Robert_LeClair
Yes, for Transformation path, click the dropdown and set it to none.  Does the raster tilt correct itself?
CamiloDavis
Nope still tilted. The tilted data is new data that I added to the map. The data that is straight up and down I created from other raster layers.
If that helps
Thankss
DanPatterson
MVP Esteemed Contributor
What type of raster?  Is it a tif with a world file?  (*.tfw) or another type of raster with a world file? (use windows explorer to confirm whether there are any other auxiliary files associated with the raster
... sort of retired...
DanPatterson
this may help
Set map properties—ArcGIS Pro | Documentation
