Hey
I am struggling with comparing to raster layers because one of them is at a different angle. I checked the projection and they both match. The pixel types are different one is short and the other is double precision but i am not sure how to change that or what else to do.
Interesting. Is there a Geographic Transformation applied in the Map View properties by chance? If so, remove it and see if the raster returns to proper XY axis.
How do if figure that out. Where can I find Map View properties?
Is this what you mean?
Yes, for Transformation path, click the dropdown and set it to none. Does the raster tilt correct itself?
Nope still tilted. The tilted data is new data that I added to the map. The data that is straight up and down I created from other raster layers.
If that helps
Thankss
What type of raster? Is it a tif with a world file? (*.tfw) or another type of raster with a world file? (use windows explorer to confirm whether there are any other auxiliary files associated with the raster
