The Split tool causes a shift in vertices and polylines on the map in ArcGIS Pro Help
4412
13
12-02-2024 12:58 PM
KathleenDuffy
Hello,
Has anyone encountered an issue with the split tool in ArcGIS Pro, where it causes vertices to shift when splitting polygons? I work with polylines regularly in ArcMap and never had this issue, but since migrating to ArcGIS Pro, I've found the split tool unusable for polygon splits. I saw that Bug BUG-000165171 was reported, but I haven't found a resolution yet. How are you handling polygon splitting in ArcGIS Pro?
Any help would be appreciated!
Scott_Harris
@MatthewParkman I see. That is definitely larger than the XY tolerance. Can you send me that project? I just tried your steps in my own map and I don't see a significant gap:
I'll DM you my email address
MatthewParkman
Sure thing. Thanks for taking a look at it. Multiple users in our organization have seen similar phenomena.
Scott_Harris
Hi @MatthewParkman , I sent you a direct message in the Esri Community site with a way to share the project with me. Did you receive it?
MatthewParkman
XY tolerance settings:
