The input path contains spaces glitch in ModelBuilder
15377
28
03-05-2025 12:15 PM
RyanWalter
Have run into an error I have never seen before nor have any clue how to resolve at this stage. ModelBuilder is telling me the input dataset I have has spaces in it. As you can see from the screenshot, no it does not.
I have tried to:
  1. Restart Arc
  2. Save the model as a new version
  3. Write the input file to a folder and geodatabase path with no spaces anywhere present
  4. Change the name of the input dataset on a re-export to a singular word
  5. Restart my computer
  6. Uninstall and reinstall ArcPro
All to no avail. Would love guidance, been doing this for 8 years and never seen something like this happen.
JoabelBarbieri
Error 010819 The input path contains spaces.
same issue here and there's no dam space!!!!!! urg
JasperRomero
@JoabelBarbieri does the solution suggested by myself and @JeremyJohnson4 work for you as well? Would be interesting to know if that is the fix, maybe that will allow someone at Esri to diagnose the issue and correct it.
JoabelBarbieri
Nope it didn't fix it
BryanBishop
It did fix it for mine, at least for now. Trying to use Basin tool and no avail, no spaces at all but the error still comes up. Then did what you suggested and it worked. When I added from the drop down, it immediately had the spaces error again. Added directly from geodatabase and it cleared the error and worked again.
dribrats
I am running into this issue as well, but it is occurring on custom scripts that I've written. These scripts have worked for years without issue and have started failing with this error in the last couple of months. At first I thought it was because they had some legacy ArcPy code in there that was no longer playing nicely with Pro, but after re-writing several of them using the latest API, I'm still running into the issue. For me, the common denominator seems to be Spatial Analyst tools. I have confirmed that the error does not occur consistently. I'll think that I've fixed it because the script will run successfully, only for the issue to crop up again on a subsequent run. I can also confirm that the input paths used NEVER contain any spaces. (such an antiquated requirement anyway). I'll let you know if I'm able to sleuth out a solution.
MinhazulIslam919
I encountered the same issue with "Error 010819: The input path contains spaces", while there is not a single space in the path, actually. Interestingly, closing the map document and ArcGIS Pro, and then reopening them, sometimes makes the error disappear. However, if I continue to use the same tool afterward, the error reappears.
TSWCD_GIS
Yep, I have this error occurring every other time I use Pro now. Like you said, closing Pro and reopening tends to fix it for me and has been my go-to work around.
MollyJordan
We are now struggling with this issue on our custom tools, only when they pertain to raster or DEM type datasets. Is there any update from ESRI regarding this issue? We have ArcPro 3.5 and updated to the most recent patch as on 10/20/25.
Molly
buckeyes82
Put your layer into a layer group and try running it again. In my case, I kept getting Error 010819 whenever I ran Zonal Statistics as Table, but it worked once the layer was placed inside a layer group.
I think it blocked again.
