Task variable in Attribute Selection?
1128
08-13-2019 07:14 AM
RickFrantz
I know it is possible to create a variable from an attribute in ArcGIS Pro Tasks. You can then use that variable in a field calculate. Is it possible to use that variable in a Select by Attributes as well?
You can also create Selection sets, but I would like to use an attribute from that selection in a new selection on another layer.
My use case is that I want a user to enter a Report Number (via task) and use that number to select records in 2 different tables.
Tags (1)
