Tables and Layout Elements in ArcGIS Pro
6748
6
10-20-2014 03:12 PM
CameronWallace
There doesn't seem to be any way to add tables to elements in ArcGIS Pro, or create reports as in previous versions...
Is there any plan to add this functionality? (either through the ability to add callouts as labels or by adding table elements as in Production Mapping)
DavidWatkins
Esri Alum
Hi Cameron,
There will not be a way to add tables to a layout in the first release of ArcGIS Pro. This is something we are targeting for a future release.
David
DavidWatkins
Esri Alum
Hi Cameron,
David
CameronWallace
Yeah... I was afraid that would be the answer. I guess I'll keep working on an alternative method of doing it using Python...
wellysulistyo_budi
I will wait for the release
ShellyKnight__GISP
Hi David,
I'm in 2.0. Any update on this issue.?
RussPrentice
Hi Shelly,
Tables are can now be added to layouts in the latest release, does anyone know how you populate them dynamically?
AnthonyMikelson
Are there any plans to support related tables in TableFrames or Row filtering based on field value?
Thank you,
Tony
