Table Window Won't Show
2109
01-22-2025 10:45 AM
StephenEJohnson
Using Pro 3.2 on a Windows 11 PC.
I normally work with three monitors. One I setup in portrait mode with tabs like Catalog, Geo processing, Attributes, etc. in the top half of that monitor and on the bottom half of that monitor I place all my open attribute tables. Today I am working with a different setup and only have two monitors. When I select to open a layer's attribute table it does not show on either monitor even in part. I tried setting my display to only use one monitor because that would normally force all windows to open on that monitor. The table window still doesn't show. I tried reset panes also with no luck. Does anyone have an idea on how I could force the window to show? In projects I saved with the table windows docked to the bottom of the main window, I can still see them.
Nelson_Schaefer
Your application settings are saved in the following two folders:
C:\Users\YourUsername\AppData\Roaming\ESRI
C:\Users\YourUsername\AppData\Local\ESRI
You can rename these folders to ESRI_old and see if the window locations are reset.
https://support.esri.com/en-us/knowledge-base/how-to-perform-an-arcgis-pro-soft-reset-000027631
MichaelVolz
Esteemed Contributor
You might need to get a third monitor again and move the table window to one of the 2 monitors that you are currently using.
StephenEJohnson
I appreciate the suggestion but that isn't possible right now. I was looking for a solution that resets the window locations or something along those lines.
Nelson_Schaefer
MichaelVolz
The caveat to renaming folders to solve this issue, is that other ArcGIS Pro settings such as other dialog box locations that are ok will also revert back to default locations so you will need to fix those dialog boxes as well.
