table not resizing
1573
03-07-2024 07:36 AM
SLouq
by MVP Alum
I have a table in my map document and when I adjust the resizing handles to make the table bigger, the handles spread out but the table doesn't resize. Which setting allows you to resize the table?
Tags (1)
MErikReedAugusta
MVP Regular Contributor
The handles only control the available space, not the used space.
If you open the Element pane (right click the table and go to Properties), there should be settings for row height and things like that.  That's really what you want to be tinkering with.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MErikReedAugusta
M Reed
SLouq
by MVP Alum
Thanks! I'll try that
