Sync Mobile Geodatabase with Python
2058
01-26-2021 07:25 PM
by Anonymous User
Not applicable
So in ArcPro you can take a map offline and it creates a local Mobile Geodatabase for each feature service in your map. I am after the recommended way to sync this mobile geodatabase in python. So far I have not found anything documented except for how to take a map offline. All I can see in the documentation is to click the sync button in the application.
Basically I want to run a script every morning before I get to work to sync all of my local copies to get the changes from the field the day before.
DanPatterson
MVP Esteemed Contributor
Create Mobile Map Package (Data Management)—ArcGIS Pro | Documentation is all that exists in ArcToolbox and nothing is an obvious candidate in python/arcpy listing
... sort of retired...
by Anonymous User
Not applicable
Yeah I know that's why I asked the question.
by Anonymous User
Not applicable
Hi Tim, did you ever find an answer to this? Thanks.
StuartMoore
did you ever get this working?
