Sync Mobile Geodatabase with Python
2061
01-26-2021 07:25 PM
Labels (2)
by Anonymous User
Not applicable
So in ArcPro you can take a map offline and it creates a local Mobile Geodatabase for each feature service in your map. I am after the recommended way to sync this mobile geodatabase in python. So far I have not found anything documented except for how to take a map offline. All I can see in the documentation is to click the sync button in the application.
Basically I want to run a script every morning before I get to work to sync all of my local copies to get the changes from the field the day before.
DanPatterson
Create Mobile Map Package (Data Management)—ArcGIS Pro | Documentation is all that exists in ArcToolbox and nothing is an obvious candidate in python/arcpy listing
... sort of retired...
by Anonymous User
Not applicable
Yeah I know that's why I asked the question.
by Anonymous User
Not applicable
Hi Tim, did you ever find an answer to this? Thanks.
StuartMoore
did you ever get this working?
