Symbolizing Continuous Linestrings by Z-Values with Arcade
955
05-04-2024 05:45 AM
ArinFranz
I have a Polyline Z layer that is single feature, continuous linestring.  I would like to symbolize the layer using the geometry Z values with Arcade or Python within ArcGIS Pro
I imagine the solution involves an Arcade expression to collect Z values and passing this to a class breaks renderer.  I have an Arcade expression that collects the Z values to an array, but I'm not sure if this is the right approach
The attached link shows a similar solution that I've used with QGIS:
https://anitagraser.com/2016/10/09/movement-data-in-gis-2-visualization/
Tagging @XanderBakker since I've seen lots of Arcade posts with your contributions.
