Symbolize polygon using 7 fields
350
07-24-2024 09:19 AM
LJackson29
Hello -
I have a building layer that has 7 fields indicating the depth of flooding for each modeled design storm (1-yr, 2-yr, 5-yr, 10-yr, 25-yr, 50-year, and 100-yr). I would like to symbolize the layer based upon which design storm a building first begins to flood (depth>0). So for example, if depth at the 1-year <=0, depth at the 2-year<=0, but at the 5-year depth>0, then it would be symbolized as "5-Year". The symbology categories would be: 1-year, 2-year, 5-year, 10-year, 25-year, 50-year, 100-year. Is it possible to do something like this using an arcade expression without creating a new permanent field in my layer? I am working in Pro 3.3 and will publish the service to Portal.
Thanks in advance.
Leila
jcarlson
You can certainly use Arcade for this. Check out the function When:
return When(
  $feature['1-year']   > 0,   '1-year',
  $feature['2-year']   > 0,   '2-year',
  $feature['5-year']   > 0,   '5-year',
  $feature['10-year']  > 0,  '10-year',
  $feature['25-year']  > 0,  '25-year',
  $feature['50-year']  > 0,  '50-year',
  $feature['100-year'] > 0, '100-year',
  'No Value'
Conditions evaluate in order, so by checking which field is greater than 0 in this order, as soon as one of the conditions evaluates as true, it returns the corresponding string.
- Josh Carlson
Kendall County GIS
jcarlson
return When(
  'No Value'
- Josh Carlson
Kendall County GIS
LJackson29
Thanks!
