Summarize Within
2547
06-21-2023 09:29 AM
temprobertcottreau131313
I regularly use the Summarize Within function but it is incredibly slow every time I do.  I'm only doing this for one polygon at a time though the layer I'm summarizing is larger.
I feel like my computer specs are at a high level.
I've cleared the Cache in Options but this hasn't been enough.
Any ideas how I can speed this up?
I've accepted how long it takes.
Not sure if upgrading to 3.1 will make a difference as we are currently running 2.7
DanPatterson
Summarize Within (Analysis)—ArcGIS Pro | Documentation
are both layers in the same coordinate system?
What options are you using for the tool?
From ArcGIS Pro 3.1 system requirements—ArcGIS Pro | Documentation
run the first link and see if it exceeds the recommended minimum (the minimum probably isn't good enough for complex geometry)
... sort of retired...
