subsurface geology using Voxel Layers
1182
12-19-2023 03:30 AM
Labels (3)
kannan123
hi all
is there any way to plot voxel layer in arcgis pro using bore hole data.? i need to create a voxel using assay value in the bore hole data and latter want to slice the voxel to see the vertical section.
LeeBrinton
Good Day. You sure can. Could you give the 3D EBK tool a try? You can either "search" for EBK in ArcGIS Pro or navigate to the Empirical Bayesian Kriging 3D Geoprocessing tool. It's worth noting that we have two EBK tools: one that is mostly focused on 2D processing and the other that was built with 3D processing in mind. When you run the 3D EBK tool, the output should be displayed as a voxel layer. I hope this helps.
https://pro.arcgis.com/en/pro-app/latest/help/analysis/geostatistical-analyst/what-is-empirical-baye...
