Store fieldnames in a string variable
2148
03-20-2024 05:54 AM
Ed_
by MVP Regular Contributor
Usually one can get the list of field/column names using the following code. Now, I would like to store the field names as strings in a variable. How can I do this?
Desired output:
var = ("Field 1", "Field2", "Field.3")
Another try (does not work either):
for field in fields:
    var = str(field.name)
Current code:
fields = arcpy.ListFields('df')
# Show column names
    print(field.name)
Question | Analyze | Visualize
2 Solutions
RichardHowe
I've taken what you asked for quite literally (i.e. replaced single speech-marks with doubles and square brackets with curly) hence the multiple replace operations on the final variable but I think it should achieve what you're after
fieldlist = []
  fieldlist.append(field.name)
var = str(fieldlist).replace("'", '"').replace("[", "(").replace("]", ")")
print var
JoshuaBixby
MVP Esteemed Contributor
The major issue you are having is that arcpy.ListFields returns just that, fields or field objects, and not field names.
var = [field.name for field in arcpy.ListFields('df')]
RichardHowe
fieldlist = []
print var
JoshuaBixby
Ed_
Hi Joshua, I might ping you, if you have sometime, since now I am trying to combine the code in your reply with the code you helped with earlier in the split comma separated values post. Thank you!
