Standalone table to Shapefile
14456
16
10-24-2022 02:04 PM
SarahRadel
Good evening, I have ran into a brick wall trying to figure out how I can convert my standalone table to a shapefile.  I am working with NLCD data and have made some calculations in excel.  I imported my excel to table and I need for the standalone table to become a shapefile.  My files do not have x/y just coord.  I am hoping someone has the answer to help me convert this standalone table to a shapefile.
Thank you so much in advance.
2 Solutions
DanLee
by Esri Regular Contributor
This table, USA NLCD Land Cover, is very different from the csv you shared.  This looks like a polygon feature class, probably converted from imagery/raster. It has the Shape field, showing "Polygon" type; and it has a Shape_Length field. Perhaps it has a Shape_Area field as well.
The CenterX and CenterY values you have are not long/lat but likely projected coordinates (in meters or ft). When you use Display XY (or actually the Table XY To Points tool), the default for Coordinate System is a GCS (geographic coordinate system), which takes the input xy values as long/lat (in decimal degrees).
You need to find out what projected coordinate values are in the CenterX and CenterY fields and specify that projected coordinate system (PCS) to run the Display XY tool.
DanLee
Yes, you can change your Map - Properties - Coordinate System.  Or you can project your data to a desired projection using the Project tool.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/project.htm
DanLee
Are they supposed to be polygons? So you have lat/long of the vertices and polygon IDs?
SarahRadel
They are supposed to be thematic
DanLee
Can you share a sample data or show a screenshot of the table?
SarahRadel
Absolutely!  Thank you so much for helping me.
DanLee
The csv contains only one row. I don't see any coordinates. Are the coordinates missing from the table? Without coordinates it's impossible to make it a shape.
SarahRadel
I am using nlcd imagery
SarahRadel
So, I copied the center x and center y for the last and added it to my table and then did a display x/y and it did not keep my data 😞
DanLee
SarahRadel
I see that it is projected in North America Albers Equal Area Conic in meters.  I'm going to give it try. Fingers crossed!
