Stack Profile
1829
04-03-2017 05:48 AM
IvanoGasco
I want to share what seems to be a bug.
I noticed that Stack Profile tool (3D Analyst) does not take into account coordinate system trasformations
set in the project. Therefore, if I want that that correct xyz were extracted from the raster along different profile, they must be in the same coordinate system.
Cheers
KoryKramer
Esri Community Moderator
Ivano, can you elaborate on how you noticed that the Stack Profile tool isn't accounting for the transformation?
Do you have the transformation set in the tool's environment setting? Geographic Transformations (Environment setting)—Geoprocessing | ArcGIS Desktop
If we need to dig deeper, are you able to send data and steps that demonstrate the issue?
IvanoGasco
Hi Kory,
well, if I set the tranformation in Stack Profile Environments tab all is fine.
ArcMap doesn't need to set it however. It takes into account the trasformations set in the Data Frame Properties.
Is that the normal behaviour for ArcGIS Pro?
