SQL server photos to Arcmap
2140
03-28-2019 05:05 AM
LieslDe_Swardt1
Hi All,
We are busy with data capturing and have a bunch of geotagged photos in our sql server. I am trying to view these photos in arcmap / arcgis pro.
The process I have followed so far:
   - Restored the .bak file in sql express in order to see the tables
   - Connected the database to arcgis pro
         - it consist of two tables (1) displaying lat and long coordinates (2) photo table with the doc ID in. Both these tables             have the doc id.
I have displayed the points as per the coordinates, the tricky part is now linking the photo table to the points in order to see the pictures.
I have done a little bit of research and came across the tool "generate attachment table'. Not too sure how it works and if this is the path I should follow. Do I create a new geodatabase? Should I export the photo table? Just a bit lost and in desperate need of guidance.
I have a standard license.
Any advice and help will be appreciated.
Thanks.
LieslDe_Swardt1
Thank you Thomas, however I do not have the physical photos, I only have the .bak file which contains the details of the photos?
