Split Raster
2689
06-10-2023 06:04 AM
DimasPratamaPutra
Hi everyone. I have a big raster file and i want to split it based on a grid feature. I tried the split raster tool but it gave no output at all.
Tags (1)
DavidPike
MVP Notable Contributor
Is the grid in the same projection/coordinate system as the imagery?  Have you tried with a simpler base name?
DimasPratamaPutra
Yes they have the same coordinate system. I tried 0 as bas name but nothing change, i even tried the number of tiles method
RhettZufelt
Not anywhere I can test, but if you are sure both datasets are in the same coordinate system, you may try to rename/path so that NO filename(s) starts with a number, or has any decimal points or spaces in the path (except, of course, the decimal point for the file extention).
This 'used' to break a lot of the raster tools in ESRI.  Not sure if this has changed for Split by raster or not.
Worth testing if you haven't figured this out yet.
R_
