Split Polygons based on Second Polygon Layer
3574
07-25-2024 10:30 AM
MeKohler
Hi, I have a layer in which larger polygons contains smaller polygons, but the smaller polygons aren't included in the geometry of the larger polygons.  I.e. no islands.
Using the intersect tool, I was able to identify these polygons, creating a new polygon layer.
Is there a way to use the intersect layer to split the original polygon layer.  I don't want to erase these polygons, I just want them to have the correct internal boundaries.  I tried the Geoprocessing Split Tool, but I didn't get the results I was looking for. It created separate layers for each There are a large number of polygons so I'm looking for a way to overlay the 2 layers.
Michael Kohler
2 Solutions
Dan_DMR
Union should do what you need
KenBuja
MVP Esteemed Contributor
Take a look at the Union tool.
Dan_DMR
The split tool in Editor should work if it's just that feature.
MeKohler
Thanks for the reply.  It's not just this feature.  I'm trying to do this for the whole layer.
KenBuja
Dan_DMR
