Split line features into multiple lines where a polygon is "close"
2982
01-31-2024 11:56 PM
DeepSeaMapping
I have line features (Streets) and Polygons (Forest). My goal is to split the line feature into a forest part and a non forest part, depending on where the line "passes by" (within a distance of 15m) by the forrest.
In the picture you see the 2 line features with the existing endpoints in blue. I want to segment this into the new 4 segments with 1& 2 being Forest and 3 &4 being noForest
Appreciate the help 🙂
Ed_
by MVP Regular Contributor
Maybe create a 15m buffer around the polygon and then use clip tool to split the lines?
Question | Analyze | Visualize
Ed_
DeepSeaMapping
Yes thanks, i just got it. I did it with a buffer and once clip and one erase!
Ed_
Nice, if the solution works for you then please `Accept as Solution` thank you.
