Split a multi polygon
4700
03-20-2025 06:16 AM
MarcusAdamski
I have several polygons saved as one geomerty and would like to split them into separate polygons. For instance, I would like to split the below into two entities. I've tried Split and Clip functions, but I've been unsucessful. I think Split will only work if geometeries intersect, but this will not happen in this case, as I'm trying to split between the polygons. Any guidance would be very appreciated.
Using ArcGIS Pro 3.3, standard.
Marc
2 Solutions
AndreasHall
John_S
I think you're trying to take a single multi-part polygon and create separate single-part polygons.
You can use a geoprocessing tool to do this https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/multipart-to-singlepart.htm
You can also do this interactively from the editing tab in ArcPro.  Use the Explode tool in the Divide group of the Modify Features pane. https://pro.arcgis.com/en/pro-app/latest/help/editing/explode-a-multipart-feature.htm
AndreasHall
John_S
MarcusAdamski
Thanks for your help - I'll try both solutions and see what works best.
