Spatially Exporting Building Footprint polygons
562
02-05-2025 11:04 AM
rsivisuals
This should be an easy one for y'all. I have a geopackage file of building footprint polygons. I need to export them into small tiles by specifying the Extents. I do NOT want to clip them, only export whole polys. The problem is when a poly sits on the edge  of the export extents of neighbouring tiles it will be exported into both tiles so I have a duplicate.
Do I really have to calculate centroids for each poly and check the centroid against the export extents?
DavidPike
MVP Notable Contributor
What's the process, is it automated?  - something like select by location iterating through the footprints as the selecting polygon?
Select by Location
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/select-layer-by-location.htm
Already has a 'Relationship' property - 'Have their center in' which may solve the issue (depending on what your process is).
