Spatial Map Series - Disabled
2574
05-25-2021 12:18 PM
JToups
When I try to create a spatial map series in an existing project, the option for a spatial map series in inactive/grayed out, both in the drop down menu and in the full dialogue box. I tested it in different layouts with different maps within the same project, and got the same result.
When I create a new project and just add the data I was going to use in the map series, the option is available. Is there something I should be looking for in my existing layers that complete knocks out map series?
AubriOtis
Hi!
The only time spatial map series should be disabled is when the layout doesn't have a map frame, or that map frame doesn't have a layer that can be used for a map series. Bookmark map series should be disabled if the layout doesn't have a map frame, or the map frame doesn't have any bookmarks. If you are seeing these options disabled at other times there may be a bug in the software. I recommend reaching out to technical support  who can log a bug.
Cheers,
Aubri
