Spatial Join points and polygons
7402
10-12-2022 08:15 AM
GeoOwl33
Hi, I need some help with setting up a work flow. I am using ArcPro 2.8.2
I have a set of  data points that I need to find out which country they fall within. I do have a country polygon shapefile as well to use as the reference. My initial thought is that I would first have to do a spatial join. Would this be a one-to-one or a one-to-many join operation? This part seems straight forward to me that after the spatial join it will create a new feature class of the combined features. The next steps is where I am lost. How can I populate the country field in my original point feature from the joined feature class?
Thank you so much for your help
DanPatterson
MVP Esteemed Contributor
Did you try spatially joining the polygon to the points?
Spatial joins by feature type—ArcGIS Pro | Documentation
Spatial Join (Analysis)—ArcGIS Pro | Documentation
... sort of retired...
GeoOwl33
Hi Dan,
Yes I did run a spatial join Target = the data points Join feature = Country shape file Join operation = one-to-many Match operation = intersect
Now I have a newly created feature class of the joined features. and my question is how do I populate the country field in my original point data feature class ?
DanPatterson
Is there not a common ID field between the original and new? which you can use for an attribute join?
GeoOwl33
Yes there is. However I did find the too called " Join Attributes From Polygon" which did the trick and then I was able to just do a simple field calc.
Now If I were to have a polygon feature that I wanted to know which country it fell within how could I do that. I do have a world countries polygon shapefile to use as a reference
