Spatial Analyst enabled for user but cannot be accessed
3548
10-07-2021 07:13 AM
ChristopherThiry
I am the Administrator for our Arc system here at medium-sized university.
I have a class that needs to use Spatial Analyst.  I have enabled this extension for all in the class.
HOWEVER, some students cannot use it--it is not an option that they cannot access.  I have attempted to enable Spatial Analyst for each individual.  The system says they are enabled.  No luck.  I have had the students sign out of their systems & reboot their computers.  Nothing changed.
Submitting a help ticket does no good because it just comes back to me.
Please help.  I need to resolve this immediately for the class is working on an assignment.
Many thanks
Chris Thiry
Map & GIS Librarian
Colorado School of Mines.
DanPatterson
MVP Esteemed Contributor
have those individuals go to the Project backstage and select Licensing to see what their actual license status for the Spatial Analyst.
What type of licensing are you using ? ArcGIS Desktop licensing—ArcGIS Pro | Documentation
@curtvprice  FYI  mining school in trouble
Curtis might provide some more target help
... sort of retired...
curtvprice
You didn't say ArcMap or ArcGIS Pro. If ArcMap, and ArcGIS Administator app says they are licensed for Spatial Analyst, students need to go Customize > Extensions and turn it on.  If Spatial Analyst is not shown as licensed in ArcGIS Administrator, you need to update their license file (single use) or license server (concurrent) to support Spatial Analyst. Assigning Spatial Analyst in ArcGIS Online does not provide extension licenses to ArcMap, it's authorized from license files, not by username.
In Pro, extension licenses should just work, if the user is authorized from ArcGIS Online by the site administrator.
Since you have an academic license there is no reason not to license everyone for everything when you set up the license files.
curtvprice
@ChristopherThiry  greetings from the South Dakota School of Mines!
Re support, instead of asking for help on the arcgis.com site, you should request support from MyEsri (http://my.esri.com) or go to http://support.esri.com.  If you do not, someone in your organization has right to call - the phone number is also available at both those locations.  Hope this helps.
SamQuon1LCC
Chris,
I know this is an old post, but I encounter the same issue today with my students. This was fixed by going to "Configure you licensing options" and changing their license type to "Named User License", which pull the license from the ArcGIS Online Organizational account.
