I am trying to create space time cubes from discrete locations with measurements that can't be aggregated. I want to only show records where there is a reading and need to set the interval for one day.
The problem is that 365 bins are created per year/per location and this is just too much - not visually what I want and draws too slowly to be useable.
Is it possible to ONLY display bins only for records in your input, rather than a bin for every day for every location being created (and given a misleading value of zero)?
This would display discrete bins 'floating' at different heights (dates) above the ground, which would be great, but I can't figure out how to make that happen.
Thank you,
Randy McGregor
