Sort/add layers Alphabetically in Pro TOC?
8034
10
09-18-2017 04:43 AM
TheodoreF
ArcGIS Pro 2.0.1 trial.
Using the add data button, I browse to a folder containing 40 or so polygon shapefiles (all sorted A-Z):
I select them all and click OK to add the files to my current project. However, the new layers are listed in reverse alphabetical order!
It's really tedious to manually drag each layer into the correct order...
Where is the option to Sort layers (within a group layer in this case) A-Z?
Theo
DavidNovak
Hello @SWATConsultingInc
technically yes, I quest.
Copy the group you want to sort, open new blank map, past the copied group and sort whole map. Then copy this sorted group again and past it in old map. Remove old unsorted group.
It's more of a workaround then solution, but works. 😉
Hope this helps.
David
