Snapping
6816
10
03-06-2024 06:56 AM
SLouq
by MVP Alum
I have a question about snapping.
I am working with line features and notice the vertexes of my lines are not snapping to the edges of lines they are intersecting with even though I have edge snapping turned on. The embedded image shows how they are not snapping. Can someone show me what snapping tool has to be on in the snapping settings?
Tags (1)
jimmykalro
It sounds like you might need to enable vertex snapping in addition to edge snapping. Edge snapping lets you snap along another line’s edge, but not directly to its vertices. Try turning on vertex snapping (the square icon) in the Snapping toolbar or Snapping Settings window, and make sure the correct layer is checked as snap-enabled. Also verify that your snapping tolerance isn’t set too low — increasing it slightly can help if the vertices are very close but not quite snapping.
