Smooth Line tool issues
3899
09-09-2019 03:58 PM
AdrianWelsh
MVP Honored Contributor
Hi, I am trying to smooth out some contours using the Smooth Line tool in ArcGIS Pro 2.4.1. Each time I run the tool with the PAEK algorithm, an attribute table is produced with with my contour data but the geometry is all <null>. It's weird because it takes awhile to perform the process but it still produces no geometry.  I decided to try the Bezier algorithm and still got the same result - a bunch of nothing.
I saw this thread from a long time, it sounds like people have had the same issue without any resolve:
https://community.esri.com/message/32406
Background: I have a large plot of land (>400 acres) with LiDAR data that is high resolution. I made contour lines out of this and I get a ton of jagged edges and lots of sorta irrelevant points (it's thick and dense - like 35,000 lines). I just want to smooth it down and make it look nice!
Any ideas?
Oh, and why is it when I zoom in that my lines get chunky and don't change based on scale? Is that a new feature?
tagging: 3D‌, LIDAR Resources‌, Lidar and other point clouds‌, Elevation Data‌, 3D Mapping
KoryKramer
Esri Esteemed Contributor
I think we may have addressed the line "chunkiness" over on https://community.esri.com/thread/239902-line-thickness-and-scale-what-happened
VinceE
I don't think this is the best way to create smooth, aesthetically pleasing contours. I have found the best approach is smooth the source data, rather than the contours lines. Try using Focal Statistics on your DEM (which I assume you have access to, since you referenced lidar) first, and THEN running contours.
