SLPK Publishing Fails
2052
05-01-2020 05:33 AM
JasonJordan00
I have two SLPK files received from vendors. One is 4gb and the other is 20gb. When using the 'Share Package' tool in Pro to publish the larger layer out to our Portal I receive  'ERROR 002934: Failed to publish web layer'. It looks like the SLPK uploaded into My Contents but the publishing failed. The smaller file was published just fine. Am I hitting a size limit?
JonahLay
Hi Jason,
Are you sharing the package to ArcGIS Online or an ArcGIS Enterprise portal? If it is to ArcGIS Enterprise, can you check the server logs?
See the following documentation:
Server logs—ArcGIS Server Administration (Windows) | Documentation for ArcGIS Enterprise
Best,
Jonah
JasonJordan00
We are publishing to our Enterprise, which is an Esri-managed Azure setup. Someone in Esri checked the logs for us and they said nothing stood out in the logs for why it was failing.
JonahLay
Hi Jason,
Can you try publishing the hosted web scene layer directly from your portal? See this: Publish hosted scene layers—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Jonah
