Single Feature, Multiple Datasets
927
06-07-2022 08:03 AM
Labels (3)
JustinFetzer
ArcGIS Pro (whatever is newest)
I have a handful of groundwater monitoring wells that are tested quarterly. I would like to be able to display all of the data for each well on single point for each well. I would like all of the data to display on a pop-up, be able to use a time slider to display changes in contaminants in a single heat map type symbology or plume, and also be able to create charts while in a web app. Currently, I display each well and it's data in a separate feature by date. I work at an engineering firm and my boss is not very tech savvy and he insists on being able to have all of the data in a single point. He does not want to have to go date by date to look at the historical change. Any suggestions on achieving this, an idea that will work better than what I am currently doing, or a point in the right direction would be greatly appreciated.
P.S. My boss apparently used to work somebody years ago that could do this as well as a bunch of other stuff that I have no idea how to do and talks about him as if he was a GIS god.
HeatherFox1
I'm curious if you were able to figure this out. I'm needing to do almost exactly the same thing.
